Knobby volume control Unique volume widget app
30. 01. 2020 09:05
Knobby volume control Unique volume widget app v1.15
Popis: Knobby přináší do vašeho chytrého telefonu Android zcela nový vzhled s cool ovladačem hlasitosti knoflíku. Aplikace pro ovládání hlasitosti s cool uživatelským rozhraním a mnoha tématy, které si dychtivě vyzkoušíte.
https://play.google.com/store/apps/details?id=com.bhanu.knoby.knobvolumecontrol
https://www.uploadship.com/ca6adaa613c9bcef
https://uploadrar.com/07wovjhkti58
http://ul.to/8zauu4y5
https://webshare.cz/#/file/2ao29536I1/knobby-1-15-apk
Knobby gives you the classy rotary controls to manage volumes available in android system. example: Ringer volume, system, notification, media, music or incall voice volume.
Knoby makes it easy to manage volume levels by gesture volume control. gesture control provides very convenient and easy way to handle different volume levels quickly from anywhere.
Busted Volume buttons? Knobby to the Rescue!
Knobby app is savior for volume keys, using Knobby you can avoid pressing physical volume hardware keys every time.
◇ Knobby have many UI themes for dashing cool look for your phone. with elegant volume control UI, app also provides easy and battery friendly access to control volumes quickly from any where.
◇ You do not need to close or exit the currently running app or game.
Knobby is just one swipe away, with gesture control you can quickly open volume control slider from any app. its runs on top of the other apps.
◇ Knobby is fully loaded with many other features that gives you total control over your phone volume settings. app have inbuilt volume control widgets and volume control notification. with so many options to configure and change the colors, icons and ringer modes.
◇ Knobby volume slider also have option for ringer modes to easily change the ringer modes, Silent, Normal or vibrate.
