27. 03. 2020 11:23
edge [substratum] [LITE]
edge [substratum] [LITE] v8.0 [Patched]
Požadavky: Android 7.0 a
vyšší
Popis: Představujeme hranu substrátu: Návrh materiálu tak, jak by měl být.
https://play.google.com/store/apps/details?id=dejan.llevo3.edge
https://dropapk.to/moqr693hnjob
https://upload.ac/0416fs3h9sv0
https://www.uploadship.com/bef8f919e65c66bb
• Theme works best with custom 7.1.x/ 8.x ROMs with OMS support
• Theme also works with Google stock 7.1.x/8.x ROMs (note that stock ROMs have some theming limitation)
• OxygenOS and LineageOS aren't fully supported (use at your own risk)
• You need substratum app from the Play Store to apply the theme
• You need to be rooted
IMPORTANT! When you open the theme in substratum app you'll see the drop down menu on top of the overlays. You need to choose one depending of your ROM Android version. There are also some overlays with different variant for specific Android version.
NOTE: AOSP apps like Clock, Messaging, Gallery, Contacts and Dialer may or may not work on Nougat ROMs, because every custom ROM has their own variant of those apps, so if you get an error while compiling, just don't install them.
After every update I recommend clean install (uninstall all the overlays from the previous version, and then install the new ones)
Don't report bugs if you're using custom DPI
WHAT'S THEMED
System, main Google's and third party apps Dotazy na SZ.
16. 05. 2020 08:06
edge [substratum] [LITE] v8.0 [Patched] 26.02.2020
vyšší + Substratum Theme Engine + Root
Vytvořeno téma „LITE“ (odstraněno všechny překryvné aplikace, nyní je k dispozici pouze systém)
https://www.uploadship.com/603ae22d79e6548c
https://uploadrar.com/0p166ouitref
https://dropapk.to/hhe8sayan43x
https://upload.ac/lsh71yjlwiwj
https://mixloads.com/8ek2nt248nxk
https://uloz.to/file/H0Grze1pzgib/edge-v8-0-p-apk
https://webshare.cz/#/file/oP0IaMtVcx/edge-v8-0-p-apk
13. 08. 2020 17:01
edge [substratum] [LITE] v8.2 [Patched]
Požadavky: Android: 7.0 a
vyšší Substratum Theme Engine + Root
- Added Support for Android Q
- Added Google Dialer
- Added Google Mesagges
- Added Google Contacts
- Added Play Store
- Added Gmail
- More Soon
- Misc bug fixes and improvements
https://uploadrar.com/wuaf5ltdybf9
https://dropapk.to/rpmis4lwoed1
https://mixloads.com/niq0q03ns93p
https://www.uploadship.com/3c6533c17af3b529
https://ulozto.sk/file/zOhTEZsEi5NN/edge-4allmobile-eeu-apk
